when to pull the tape
AtTheBrink
Post by AtTheBrink » Wed May 28, 2014 6:33 pm
Should I be pulling the tape after each coat of paint? Or can it tape stay till the final coat?
Mike
Matthew 4:19
Re: when to pull the tape
Post by tech_support » Thu May 29, 2014 9:05 am
For the thinner LPU's I normally wait until I'm done, it should break free if you pull at a high angle. For thick paint (kiwigrip counts too) you need to pull quickly before it skins over.
AtTheBrink
Post by AtTheBrink » Thu May 29, 2014 1:06 pm
Thanks Joel.
Mike
Matthew 4:19
willg
Post by willg » Thu May 29, 2014 10:03 pm
I'll add also that I recently painted my hull with 3 coats of Sterling and pulled the tape the day after the third coat was on. The tape came off easily and here was no lifting of the paint. My coats were fairly thin.
remedy32
Post by remedy32 » Fri May 30, 2014 7:18 pm
Have to agree with Joel on the how part. All LPU paints form a continuous cross-linked film which can be very prone to problems when you remove tape. They can behave a lot like latex trim paint does when people try to tape home window panes and wait too long. When spraying, where you can do 2-3 coats in an hour or two, we pull the tape as soon as the last coat flashes off the solvent and is sort of dry to the touch. Pulling the tape almost over itself and away from the finished edge is best. Whatever you do don't pull the up and toward the finished area, that's begging for a problem.
Bill
Users browsing this forum: No registered users and 14 guests
