Eric's C21
Larry B
Re: Eric's C21
Post by Larry B » Fri Nov 08, 2019 8:46 am
Eric, I am watching your build, I don't reply or post much but just wanted to say looks like your doing a fantastic job, That will be one fine boat.
Just watching from Arizona,
Larry B
Completed: FL14, OD18
Re: Eric's C21
Post by Eric1 » Fri Nov 08, 2019 9:47 am
Thanks Larry. :D
Re: Eric's C21
Post by fallguy1000 » Fri Nov 08, 2019 6:50 pm
I am a little jealous of this build. It will be a kick ass boat when done and about 15% of the work of the Skoota dm.
I am feeling a bit overwhelmed these days.
glossieblack
Re: Eric's C21
Post by glossieblack » Sat Nov 09, 2019 4:57 am
Hey Fallguy, both Eric's and your builds are A1 first class sensational. Don't forget you're building two boats. :wink:
Re: Eric's C21
Post by OrangeQuest » Sat Nov 09, 2019 5:20 am
AT THE SAME TIME!! :lol: :lol: But I agree, both Eric and Fallguy are doing fantastic jobs.
Re: Eric's C21
Post by Eric1 » Tue Nov 12, 2019 11:10 am
Thanks Fallguy1000, You hang in there. You'll get that yacht finished, step by step. 8)
Thanks to you Glossie and OrangeQuest. :D
I have the tops filled with the exception of the stringer sections where the gas tanks will go.
I will temporarily mount cleats with release film to build those areas next and fill the tops.
Then I will sand and confirm level before I finish the rest of the cleat work.
All of the dowels were filled this morning as well.
We are going to be very cold the next few days so boat progress will be on pause.
I'm pulling small fillets at the cleat corners. It's probably not needed but I like the idea.
Re: Eric's C21
Post by Jeff » Tue Nov 12, 2019 11:34 am
Really nice work Eric!!!! Jeff
Re: Eric's C21
Post by OrangeQuest » Wed Nov 13, 2019 4:59 am
The small fillets are a nice touch.
glossieblack
Re: Eric's C21
Post by glossieblack » Wed Nov 13, 2019 5:14 am
Eric, very nice and precise. 8)
Re: Eric's C21
Post by Eric1 » Thu Nov 14, 2019 11:52 am
Yesterday I made dams and put them in place.
I had a late start but good grief it took a while to do.
This is all I accomplished as I had to run a bunch of errands.
Today I wait until 8:00 to get started. Temp in the building was only 56 degrees.
The epoxy was like honey and tough to mix and use. None-the-less I have the dams filled.
Nothing else today, this work must cure first.
Mistakes corrected, Finally nice and level! :)
I'm really looking forward to this part of the build being done. :D
Users browsing this forum: OlivierP and 1 guest
