28 Bertram Restoration Boat 2
Mbiggerstaff
Post by Mbiggerstaff » Mon Jan 07, 2019 8:21 am
Saturday was a glassing day. Almost got all of it done but ran out of resin. Have a friend who works at one of the big boat builders in Wancheese. He shared with me how they lay their glass so I gave it a try. They mix Carbocil with their epoxy and then trowel it on. The glass goes on next. They then use a plastic trowel and scrape any excess paste out from beneath the glass. this is followed by brushing on epoxy followed by another troweling to remove excess. I had some release film that I then applied on top of that on part of it to see how it worked. I used extra slow harder to give myself plenty of time. End result. Its a really nice way to do it. Don't have to contend with a bunch of bubbles under the glass or excess epoxy dripping everywhere. The part that I covered with the release film came out really nice. Smooth and ready for spray fair. The other will require some sanding.
Post by pee wee » Mon Jan 07, 2019 9:24 am
They mix Cabocil with their epoxy and then trowel it on. The glass goes on next. They then use a plastic trowel and scrape any excess paste out from beneath the glass. this is followed by brushing on epoxy followed by another troweling to remove excess. I had some release film that I then applied on top of that on part of it to see how it worked. I used extra slow harder to give myself plenty of time. End result. Its a really nice way to do it. Don't have to contend with a bunch of bubbles under the glass or excess epoxy dripping everywhere. The part that I covered with the release film came out really nice. Smooth and ready for spray fair. The other will require some sanding.
Interesting, sounds worth a try! What kind of release film were you using, peel ply?
Mbiggerstaff
Post by Mbiggerstaff » Mon Jan 07, 2019 10:24 am
yes, peel pry
Post by fallguy1000 » Mon Jan 07, 2019 8:54 pm
I like to use a thixo hot coat as well. Especially for any deviations in the surface.
It works super well at holding glass on vertical or upside down surfaces as well; especially if the coating begins to cure and get tacky. Although wetout is generally done away on a flat. These types of jobs are tuff.
DAYTRIP
Post by DAYTRIP » Tue Jan 08, 2019 3:31 pm
Great tip mike. I will have to give that a try.
Mbiggerstaff
Post by Mbiggerstaff » Thu Jan 10, 2019 10:41 am
Got the hard top started and some of the first step fairing done yesterday.
Mbiggerstaff
Post by Fuzz » Sat Jan 12, 2019 2:49 pm
Man you do nice work :!: That girl is going to be a beauty when done :wink:
Mbiggerstaff
Post by Mbiggerstaff » Tue Jan 15, 2019 12:56 am
Got the hard top laid up today. 3 layers of 1708 on top. Vacuum pump running. Pix tomorrow
Mbiggerstaff
Post by Mbiggerstaff » Wed Jan 16, 2019 8:13 pm
Pix as promised. Got a little work done on the window yesterday. Planning on real glass. There will be a removable panel over the console to allow access to wiring for radar, ect.
