C19 Stretch and re-build Progress Report...
TomTom
Post by TomTom » Mon Nov 27, 2017 12:22 pm
I am moving my C19 issues over here - and keeping my fingers crossed at this stage that it may become a "re-build" ...
I have managed to cut out the center console, the front locker and the motor well bulkhead, remove the floor and dig out all the foam and chase tubes.
She is one sorry looking mess at the moment.
I am waiting for a multi tool I have ordered (never knew about them till the other day) and am hoping I will be able to cut out the stringers and frames neatly - and possibly all in one - so that if they are sound, they can go right back in once I have redone the keel, chines and fabric.
They have come away from the hull on the Port side, but it seems most of the resin cured on the starboard side.
Once I have all frames and stringers out, I am hoping we can grind off that gooey mess and start again.
The hull is on its trailer and has been braced all round.
I am hoping most of the issues where resin not curing and not water ingress.
The plywood still seems sound from visually inspecting, but I am waiting for the moisture meter I ordered before I can really say anymore.
Here are some pics...
glossieblack
Re: C19 - Major Structural Issues - Progress
Post by glossieblack » Mon Nov 27, 2017 1:02 pm
We'll all be keeping our fingers crossed. Well done on keeping your cool and finding a feasible way through.
Post by Fuzz » Mon Nov 27, 2017 2:09 pm
It would be wonderful if you are able to fix the issues and save the boat. You did such a nice job building it that it would be a crying shame if you have to scrape it.
As for cutting the stringers loose with the multi-tool it can be done. That is what I used on the boat I am rebuilding now. I only had to cut 18 inches or so out on four stringers. The multi-tool did a great job but it is not very fast and you have a lot of running feet to cut out. The blades are spendy and you will need to carbide tipped ones for this task. I know some narrow minded folks here :lol: do not care for multi-tools but mine has been a huge help at times. Depending on how fast it goes and your cost of blades you might find it more cost and time effective to just sacrifice the stringers. Only time will tell but best of luck either way you go.
Post by cape man » Mon Nov 27, 2017 2:37 pm
You are a strong and brave man!
Post by pee wee » Tue Nov 28, 2017 8:55 am
I don't know if you coated the ply with resin before you laid the glass down, or if you allowed the resin to soak through the glass to the plywood on the inside of the hull, but wouldn't the resin have coated and somewhat waterproofed the ply even if it never set up? Maybe raw resin or hardener mixes with water eventually, but maybe not . .
I'm an optimist, and I hope you can get that boat back on the water! Good thing you noticed a problem when you did, wouldn't do to have things go south out on the water.
justin_dwyer
Post by justin_dwyer » Tue Nov 28, 2017 9:16 am
Good luck TomTom, I feel you man!
I love your boat to, so hope you get her back out there.
Justin
tcason
Post by tcason » Tue Nov 28, 2017 10:14 am
I am shedding a tear looking at that............
Good luck!!
peter-curacao
Post by peter-curacao » Tue Nov 28, 2017 3:46 pm
Ahh men that sucks, hope you got her up and running again fast
Post by jacquesmm » Tue Nov 28, 2017 4:38 pm
I agree with that.
Post by Eric1 » Tue Nov 28, 2017 6:47 pm
Good for you! Sorry you have to go through this but you are doing the rework the right way. :)
Users browsing this forum: fallguy1000 and 2 guests
