Crabby Patti2 C17
mohrscott
Re: Crabby Patti2 C17
Post by mohrscott » Sun Mar 03, 2019 10:18 pm
It seems very similar to taping drywall; I suppose someone has brought that up before. I am trying to put on as little faring as I can and keeping it as smooth as I can to avoid much sanding. I’d rather do it many easy sanding jobs than a few thick ones. We will see.....dome with my own fairing mix. Sand tomorrow and then Quickfair.
Post by pee wee » Mon Mar 04, 2019 9:08 am
I agree, many similarities between fiberglass tape/fairing and drywall, also plastering. The pros apply the compound smoothly so there's practically no sanding, the beginners make a lumpy mess and there's no end of dust and labor.
mohrscott
Post by mohrscott » Thu Mar 07, 2019 10:37 am
I am trying to figure out the best time to place the spray rails and rubrail; Seems that it would be easier to Quickfair, and long board the sides and bottom without these rails. I will need to fill and fair the joint between hull and spray rail however, so if I fair the bottom first, then I will need to dress up the spray rail joint......anyone have advice?
Post by Fuzz » Fri Mar 08, 2019 2:39 am
If you are able I would fair first. The rubrails sure get in the way.
Post by topwater » Fri Mar 08, 2019 7:15 am
Put the rub rail on then fair it then do the fillet under the rail at the end. But thats me :wink:
Browndog
Post by Browndog » Fri Mar 08, 2019 9:34 am
Rubrails aren’t too much of a problem, but spray rails and strakes do get in the way. The area of the hull under the rubrail doesn’t really need a lot of smoothing because you are adhering the rubrail to it and covering it up. Applying glass over the rubrail or a fillet on the underside further negates the need.
mohrscott
Post by mohrscott » Fri Mar 08, 2019 11:44 am
Thanks all; I will fair out the bottom then put in spray rail. Seems like any longboarding will be easier without the spray rail on. I think I am going to miss sanding......
mohrscott
Post by mohrscott » Sat Mar 23, 2019 2:39 pm
Back at it after a lousy bout with the flu. DIY steam box worked great for the spray rails.
mohrscott
Post by mohrscott » Mon Apr 01, 2019 11:38 pm
No one told about the sanding......
Post by Fuzz » Tue Apr 02, 2019 1:52 am
We like to save the sanding part till guys are too deep in to quit :lol:
Users browsing this forum: Sanders and 12 guests
