C19 in Richmond, VA
Dan_Smullen
C19 in Richmond, VA
Post by Dan_Smullen » Fri Aug 23, 2019 10:19 pm
Plans in hand for a few weeks now. Scheming and planning. Sourcing material, and starting at the beginning, which I believe is the strongback.
Because I'm a cad/cnc nerd, i did a quick model of the strong back and 2 piece gussets I'll cut out to keep the vertical stanchions plumb and rigid. A nest of 20 on the cnc will be a quick project.
Probably overkill, but I'm anticipating a slow build and don't want things to sag. I've ordered LSLs, (Laminated Strand Lumber) for the beams. Spaced 40" apart so the outside of the verticals align with the insides of the stringers. Next pics should be the real thing!
glossieblack
Re: C19
Post by glossieblack » Sat Aug 24, 2019 3:15 am
Welcome to the forum. Good call on the laminated lumber.
Re: C19
Post by Fuzz » Sat Aug 24, 2019 3:32 am
As long as you are planning for the strongback I would think long and hard about mounting casters to it. Big ones that are overkill. Being able to move the boat around with little effort is a wonderful thing.
Dan_Smullen
Re: C19
Post by Dan_Smullen » Sat Aug 24, 2019 8:13 am
Exactly what’s on my mind. Garage is just barely big enough to hold it, but the ability to move it around so the kids can still reach their bikes is key.
Re: C19
Post by Dougster » Sat Aug 24, 2019 10:21 am
Big nice castors for sure. My LB22 build took years and two of the castors flattened out a bit.
Dan_Smullen
Re: C19
Post by Dan_Smullen » Tue Sep 03, 2019 8:39 pm
LSLs in the house, and big, beefy castors procured!
Question regarding drawing for Station B...
There are two horizontal lines in the area of the sole, but neither is marked with a dimension from the keel or baseline. Which line is the bottom of the sole, and what is a dimension to it?
Thanks.
Re: C19
Post by pee wee » Wed Sep 04, 2019 8:42 am
The drawing is small and kind of blurry, but the designer asks that we not post any copies of the drawings, just refer to the plan page in question. Anybody with access to the plans can look to see what you're talking about.
The base line is normally the bottom of the sole, that's all the help I can offer. :?
Dan_Smullen
Re: C19
Post by Dan_Smullen » Wed Sep 04, 2019 8:56 am
Understood. Thanks for that.
Edited post above. :wink:
Re: C19
Post by fallguy1000 » Wed Sep 04, 2019 9:10 am
Any sign of Jacques?
Re: C19
Post by Jeff » Wed Sep 04, 2019 12:32 pm
Dan, Welcome to the Builders Forum!!! Also, please give Jacques a little time to respond as he evacuated the area last Friday due to the hurricane!! Jeff
Users browsing this forum: OneWayTraffic and 4 guests
